OkaManThe$Wolf
S.W.A.T. Application: Okaman In-Game Name: Okaman Score: 52131+ Country & Timezone (GMT): EGYPT & GMT+2 Website Profile: https://ls-rcr.com/user/Okaman Proof of Stats & Activity: https://ibb.co/R47WGKFr Reason: Hello everyone i decided again to applying once again to get back the rights and represent the the faction as member once again i've been always Loyalty to faction swat and i'll never give up again until i take the rights as offical member i have left already the server i have been upset from some thing which makes me to feel bad as nobody appreacite me after those all years here but i'd like to move on plus i want you granted the chance to me once again as you know i'm ex-swat member and known enough to you'all plus i want to become good addtion to the team and share my Experience i want to mention i'm actually know everything regarding the faction swat how's the system working tactics agasint suspects etc every side here so i'll be thankfull if you think currently to give chance to keep playing in cyan also since you given the last rights until26 if you mentioned i didn't break the rules or anything bad agasint peoples i hope you understand me and welcome me once again beteewn you Cheers Okaman Team 78
Kawish
LS-RCR SWAT GROUP LS-RCR SWAT STAFF COMMAND TEAM IntroductionThank you for applying for S.W.A.T.! Before your application can be accepted, you must pass the S.W.A.T. test. The test evaluates your communication skills, knowledge of the S.W.A.T. rules, and speed of commands. You will be tested by a member of the Warrant Officer team. Warrant Officer TeamHead Warrant Officer - Kawish Warrant Officer 2 - Squanix Warrant Officer 1 - Bombshell Other InformationIf you see any of them in-game, send a private message to only one Warrant Officer stating that you'd like to be tested. You can send a private message by typing /pm [id] [message]. If no Warrant Officers are online, you're welcome to submit a request in our Discord server to let the Warrant Officer team know that you'd like to be tested. Once you do, you'll be in direct contact with them. If any technical issues occur during the test, you may request to postpone it. However, complaints regarding technical issues or the testing process will not be accepted after the results have been posted. Please keep in mind that every Warrant Officer has their own testing style. While the testing procedure remains the same for everyone, minor differences in how each Warrant Officer conducts the test are completely normal. The S.W.A.T. High Command will always have the final decision. Signed, S.W.A.T. Warrant Officer Team
SPECIAL WEAPONS AND TACTICS Applicant's Name: OkamanS.W.A.T. Test Results Communication Skills: Passed The applicant and I exchanged words with confidence and transparency. Our conversation was deemed good enough and convinced me to continue with the test. S.W.A.T. Rules: Failed The applicant answered only 1 out of 3 questions correctly and has therefore failed the Rules part. Signed, S.W.A.T. Warrant Officer Team
DOCUMENT: S.W.A.T. VERDICT ReasonFailed the S.W.A.T. Rules part Re-Apply Date10 Days Other InformationYou did not pass the S.W.A.T rules part, please read the S.W.A.T and carefully before applying again and good luck! Signed, S.W.A.T. Commander Team
