Greezie wrote:Well I installed my graphic card 2 days ago and I had no problems with it but then suddenly my screen monitor started to flicker then just went completely Blank and said "dvi: no signal". so I unplugged the graphic card also the wires and connected it all up how it was in the beginning and the screen came up perfectly without any flickers at all. So I thought it was the graphic card so at the moment I've sent it back to exchange it for a new one since I fiddle with it a bit. So is there anyone who can help? Please.I fail to see a problem, you said you fixed it but you sent the GPU back? I don't understand.
[Lsrcr]Raskit wrote:I thought I did because I changed my Hz to 75 instead of 60 which put a stop the flickers on my screen but after about 1 hour it flickered badly then just went blank but I personally think it's my dvi cable because without the graphic card my screen still works but when I press one of the button under my monitor it saysGreezie wrote:Well I installed my graphic card 2 days ago and I had no problems with it but then suddenly my screen monitor started to flicker then just went completely Blank and said "dvi: no signal". so I unplugged the graphic card also the wires and connected it all up how it was in the beginning and the screen came up perfectly without any flickers at all. So I thought it was the graphic card so at the moment I've sent it back to exchange it for a new one since I fiddle with it a bit. So is there anyone who can help? Please.I fail to see a problem, you said you fixed it but you sent the GPU back? I don't understand.
