SA-MP 0.3x-R2
Exception At Address: 0x00000000
Base: 0x031C0000
Registers:
EAX: 0x00000000 EBX: 0x00000001 ECX: 0x017C07D0 EDX: 0x0000477C
ESI: 0x017C07D0 EDI: 0x00000000 EBP: 0x00000000 ESP: 0x0022FD18
EFLAGS: 0x00210246
Stack:
+0000: 0x00469FF7 0x017C07D0 0x017C07D0 0x00000000
+0010: 0x0046A220 0x81923073 0x00000065 0x0022FD94
+0020: 0x00000000 0x00000009 0xFFE1E1E1 0x80808080
+0030: 0xFF000000 0x0053BFCC 0x0000001A 0x8191F251
+0040: 0x00000000 0x0000001A 0x8191F251 0x03930A68
+0050: 0x03225896 0x0000001A 0x8191F251 0x00000000
+0060: 0x774580E0 0x0022FD6C 0x0022F924 0x0022FF78
+0070: 0x0326FAA4 0x03292738 0x00000001 0x774580E0
+0080: 0x0053E986 0x00000001 0x775661A4 0x775A6F6C
+0090: 0x0053ECC2 0x00000001 0x00619B71 0x0000001A
+00A0: 0x00000001 0x00000001 0x0000000A 0x00748DA0
+00B0: 0x0000001A 0x00000001 0x773BD8E3 0x00000000
+00C0: 0x0022FF88 0x7FFDE000 0x01660000 0x4F0191F0
+00D0: 0x016621A8 0x00000008 0x00000100 0x00000008
+00E0: 0x00000102 0x44000000 0x43C00000 0x00000000
+00F0: 0x00000000 0x00000400 0x00000300 0x00000000
+0100: 0x00000001 0x002807CC 0x00000200 0x00000000
+0110: 0x02FF0380 0x298A6BA7 0x00000380 0x000002FF
+0120: 0x0000002C 0x0022FE2C 0x00825EA4 0x773BD8E3
+0130: 0x00000000 0x7FFDE000 0xFFFFFFFF 0x00821D17
+0140: 0x00000065 0x00000065 0x0022FF88 0x008246F1
+0150: 0x00400000 0x00000000 0x018A1E0D 0x0000000A
+0160: 0x00000094 0x00000006 0x00000001 0x00001DB1
+0170: 0x00000002 0x76726553 0x20656369 0x6B636150
+0180: 0x00003120 0x00000000 0x00000000 0x00000000
+0190: 0x00000000 0x00000000 0x00000000 0x00000000
+01A0: 0x00000000 0x00000000 0x00000000 0x00000000
+01B0: 0x00000000 0x00000000 0x00000000 0x00000000
+01C0: 0x00000000 0x00000000 0x00000000 0x00000000
+01D0: 0x00000000 0x00000000 0x00000000 0x00000000
+01E0: 0x00000000 0x00000000 0x00000000 0x00000000
+01F0: 0x00824588 0x00000000 0x00000000 0x7FFDE000
+0200: 0xC0000005 0x00000000 0x018A1E0D 0x00000044
+0210: 0x018D6708 0x018D5740 0x018D3B70 0x00000000
+0220: 0x00000000 0x00000000 0x00000000 0x00000000
+0230: 0x00000000 0x00000000 0x00000000 0x00000000
+0240: 0x00000000 0xFFFFFFFF 0xFFFFFFFF 0xFFFFFFFF
+0250: 0x00000000 0x00000000 0x0022FE78 0x0022F924
+0260: 0x0022FFC4 0x00825EA4 0x00888078 0x00000000
+0270: 0x0022FF94 0x773BED5C 0x7FFDE000 0x0022FFD4
SCM Op: 0x446, lDbg: 0 LastRendObj: 0
Game Version: US 1.0chud.txd in models => txdThis is the murad's quote. Ignore the reply which instructed you to put chud.txt in models.
C_hud.cs in cleo library
Health by Dr.waston.cs in cleo library
don't put zonetexts.cs because there is already zones text in lsrcr script
Interfaceeditor.asi in the main directory
InterfaceEditor.ini in the main directory
and it should work fine.. it did for me atleast..
[Lsrcr]Maggy wrote:so what should I do with c_hud.txd?chud.txd in models => txdThis is the murad's quote. Ignore the reply which instructed you to put chud.txt in models.
[Lsrcr]Nitro wrote:C_hud.txd > models/txd[Lsrcr]Maggy wrote:so what should I do with c_hud.txd?chud.txd in models => txdThis is the murad's quote. Ignore the reply which instructed you to put chud.txt in models.
murad wrote:Doing that makes my game crash though, do I need the europe version of GTA_SA.exe or the USA version of GTA_SA.exe?[Lsrcr]Nitro wrote:C_hud.txd > models/txd
[Lsrcr]Nitro wrote:Ye thats true i needed to install another gta sa also before i could try to install it i guess you can't use it.murad wrote:Doing that makes my game crash though, do I need the europe version of GTA_SA.exe or the USA version of GTA_SA.exe?[Lsrcr]Nitro wrote:C_hud.txd > models/txd
EDIT:
I'm pretty sure I need the USA version, tried playing with the EU version but it tells me I need the USA version.
[Lsrcr]Nilikos wrote:Lmao, it's not about installing another GTA, it's about using a USA crack which I've got, just having problems with the mod itself.[Lsrcr]Nitro wrote:Ye thats true i needed to install another gta sa also before i could try to install it i guess you can't use it.murad wrote: C_hud.txd > models/txdDoing that makes my game crash though, do I need the europe version of GTA_SA.exe or the USA version of GTA_SA.exe?
EDIT:
Want me to lock this?
