S.A. Army In-Game Rules
These rules apply to members of the S.A Army only!
General Army Rules
- S.A. Army applicants have to complete their S.A. Army in-game test within 10 days after submitting their S.A. Army application. Not meeting this requirement will result in application being denied. However, exceptions may be made if valid reason is stated.
- You may not argue with other players or with other Army members as well as with other members of another group or faction. Army members are required to maintain good manners & discipline at all times. Note: Be humble in victory & gracious in defeat.
- You may engage Medium Wanted, Highly Wanted and Most Wanted suspects who are or inside the Army Zone (the entire purple area shown on the map) with any Army vehicle or weapon without using /su and without air, water or ground restrictions.
- You may open fire on wanted suspects (those specified in the rules of the vehicle) without /su if you are attacked/being shot at by them.
- You may use the grenades only on Medium Wanted, Highly Wanted & Most Wanted suspects. You may not use the grenades against Hitmen when having a hit contract.
- You may not use the Army skin for chilling or roaming around. You may use the Army skin only for serious roleplay.
- You may not go Away From Keyboard (AFK) for more than 20 minutes while playing in Army skin.
- You may not use the Army skin if there are already 15 players using the skin & playing as Army.
- You may not use heavy Army vehicles (Rhino/Hydra/Hunter/Rustler/Sea Sparrow) or Grenades inside the Turf zone while it is under attack (this rule does not apply when the turf is stable and not under attack).
- You have to be active on the Forums as well as in-game.
- When using an army vehicle that requires /su in order to fire, you must /su the driver or any passenger that is inside the vehicle. (Passengers/those on top will see the warning also)
- Any attempt of spreading faction hate or propaganda (example: Swat sucks and all Swat members should join Army) is not allowed and will be severely punished.
- Do NOT engage suspects that were engaged first by SWAT.
- You cannot participate in the server events in Army skin.
Civilians Interaction Rules
- You may engage with any Army vehicles and weapons wanted suspects who are teaming with Civilians (White/Yellow) without prior warnings (while following the specific rules of the vehicle or weapon being used) if the civilians are nearby and are:
- On foot.
- Standing on top of the suspect's vehicle.
- If an innocent (White/Yellow) is in a vehicle with a wanted suspect, you may engage the suspect only after warning the innocent using /su and waiting for the timer to expire. This requirement still applies even if the wanted suspect attacks you first.
- These rules do not apply to Hitmen while you are carrying a hit contract. You are never allowed to engage Hitmen with any army vehicle while carrying a hit contract.
Rhino Tank Rules
- You may not use the Rhino against Medium Wanted suspects or Hitmen when having a hit a contract. You may use the Rhino against Medium Wanted suspects if they are teaming with a Highly Wanted or Most Wanted suspect after using the /su and waiting for the timer to expire.
- You may engage Highly Wanted & Most Wanted suspects with Rhinos' main gun, after using /su and waiting for the timer to expire.
- You may use the Rhino to ram Medium Wanted suspects vehicle in order to disable it.
- You may engage wanted suspects using Rhino who are in air or water without using /su (also applies when they are on ground in a flying vehicle).
Hunter & Sea-Sparrow Helicopters Rules
- You may not use the Hunters weapons (minigun or rockets) against suspects who are on foot, on the ground, or standing on rooftops. You may use the Hunter's blades against such suspects.
- You may use Hunter/Sea-Sparrow against Medium Wanted, Highly Wanted or Most Wanted suspects who are in the water or who are airborne. (also applies when they are on ground in a flying vehicle.)
- You may use the Sea-Sparrow against Most Wanted suspects who are on the ground after using /su and waiting 5 seconds for the timer to expire. This rule also applies to Highly Wanted suspects who are teaming with them, but it does NOT apply to Medium Wanted suspects.
Secret word = First two letters of your in-game name + current month and year. Example: Energ's secret word in January 2025 would be En0125. Add it to the bottom of your application to confirm that you have read the rules.
Hydra Jet Rules
- You may use the Hydra to engage the Most Wanted suspect only when they are on the ground after using /su and waiting for the timer to expire.
- You may use the Hydra against the Most Wanted suspect who is teaming with Highly Wanted suspects after using the /su on any of the suspects.
- You may engage Highly Wanted or Most Wanted suspects in air or waterborne with Hydra without using /su (also applies when they are on ground in a flying vehicle).
Rustler Plane Rules
- You may use the Rustler against Medium Wanted, Highly Wanted, and Most Wanted suspects who are on the ground after using /su and waiting 5 seconds for the timer to expire.
- You may use the Rustler against Medium Wanted, Highly Wanted, and Most Wanted suspects who are waterborne or airborne without using /su.
- You may not use the Rustler under any circumstances against Hitmen when carrying a hit contract.
RPG Rules (Staff Sergeant+)
- You may use RPG on Medium Wanted, Highly Wanted, and Most Wanted suspects who are airborne & waterborne without using /su.
- You may use RPG on Medium Wanted, Highly Wanted, and Most Wanted suspects who are in a flying vehicle (also applies when they are on ground in a flying vehicle).
- You may not use the RPG under any circumstances against suspects who are on foot (except the Army zone).
Punishment(s) for breaching these rules vary & the severity of the breach is also taken into consideration. As a punishment you may receive: a verbal warning, an official Army warning, a demotion and/or dishonorable discharge.
Keep in mind that along with Army rules, Ls-rcr rules also apply in-game.
S.A. Army High Command
