Dani6 wrote:Hi,Right click on Gta Sa click on properties and goto compability bar and there tick the check box and select from the drag box Windows 98 and click on run as admin and click on apply and ok. If it doesn't helped post it here.
I'm experiencing a problem since i've installed some Skin mods (tried removing every mod, even tried re-installing the game & persist on crashing), i'm using Windows 8 & my game isn't (prbably obviously) original, when i click on 'new game' (start a new profile) it just delays 1-2 seconds to stop & pop up a message saying: Gta_Sa.exe has stopped working, i tried with Computer > right click > prop. etc... & also i tried running the game as administrator, also happens when i try to load a saved game.
Is there any solution?
If there is, i would be thankfull if you could share it.
BeaTen. wrote:I've done the instructions well, Windows 98 - Run as administrator, i've tested the program & it persist on crashing instantly after i select: 'new game', any other possible solution?Dani6 wrote:Hi,Right click on Gta Sa click on properties and goto compability bar and there tick the check box and select from the drag box Windows 98 and click on run as admin and click on apply and ok. If it doesn't helped post it here.
Dani6 wrote:Leme think about it..BeaTen. wrote:I've done the instructions well, Windows 98 - Run as administrator, i've tested the program & it persist on crashing instantly after i select: 'new game', any other possible solution?Dani6 wrote:Hi,Right click on Gta Sa click on properties and goto compability bar and there tick the check box and select from the drag box Windows 98 and click on run as admin and click on apply and ok. If it doesn't helped post it here.
Stormocide wrote:Can u tell me where u downloaded Gta sa from?
This may be the issue.
Dani6 wrote:Do you want the GTA SAN ANDREAS i have?Stormocide wrote:Can u tell me where u downloaded Gta sa from?
From Mediafire (No torrent), it came with a .zip folder which contains the whole GTA Sa directory files (Models, audio, .dlls etc).
The link came from a video which not long ago got removed by the author.
EDIT: Spelling.
Stormocide wrote:If it's possible, through a Forum Pm. thanks.Dani6 wrote:Do you want the GTA SAN ANDREAS i have?Stormocide wrote:Can u tell me where u downloaded Gta sa from?
EDIT: Spelling.
I mean not the one I have, but the link of where I got it from?
Its not modded.
