Moiz Nouman wrote:Well, what ranks do you have in mind ? I'll give my opinion about this suggestion after I know what ranks are going to be added and between what rank.Private II: Between private & private first class.
Kaosx234 wrote:I don't see any advantage of having those 2 ranks, unless you reached the max. rank like BoSS.That is the point, there is no advantage, also this is why i said it would receive more negatives rather than positives, since they are 'useless' in most of its aspects, they are just to be an obstacle between you & your 'wish' to reach a higher rank, will focus on loyalty as well, either you need patience or you leave the team because you won't get quick the rank that you wish.
In life, it's not the most genetic person who wins or the guy who has the most potential to win. It's the person with perseverance who wins. Always wants to get up and go at it again. That's the guy you need to be! - Greg Plitt
noʎʞɔnɟ wrote:Commander II specifically made for Table.
CyClon3 wrote:How about adding 1 Lieutenant rank [LT] [Lt.] after the end of the sergeant ranks?This would be a great addition as well, but the LT can have different privileges (due to its position, what kind of privileges? i don't have any idea yet), but if the 'original' suggestion stands would be to add three ranks more, otherwise remove one of them (PVT II & SGM), i'll update the suggestion to add the three ranks if i see commentaries supporting this.
