/locked
Like to set up your own film-making group ? Want to join a car racing group ? Here you can find a collection of diffrent user-owned groups to join.
7 posts Page 1 of 1
Swaka
[Lsrcr]Swaka
Post by Swaka » November 11, 2014, 1:12 pm
The Story
It is true that some criminals commit crimes again after they have been punished. While there are several reasons for this alarming trend, some effective measures can be taken by governments to tackle this problem.
There are two main reasons for re-offenders. Firstly, the prison system can make the situation worse. Criminals put together in prison and they make friends with other offenders. While they are locked up in prison, they do not have much to do there, and they would exchange information about what they have done before they came to the prison or they may plan crimes with other inmates. Secondly, offenders often do not have any other means of earning money. They are poor, uneducated and lacking skills needed to maintain a job. Also, a criminal record makes finding a job difficult as people usually avoid hiring ex-convict.
To solve this problem, governments should focus on rehabilitation of criminals rather than punishment. Above all, prisons need vocational training which makes inmates to prepare for life outside the prison. They can learn practical skills such as computer programming, car maintenance and graphic design. In this way, they can be hired for a position that requires this certain knowledge and skills. Community service is another way to reform offenders. Rather than being locked up in prison with other inmates, offenders can help society and become useful to their local community, and these activities would eliminate the negative influence that prisons can have.
Members
[Lsrcr]Sonit
[Lsrcr]Inzane
[Lsrcr]Abdul. [HTO]
[Ls]Saeed [TO]
Promentheus
Geografi
[Lsrcr]Rex
H_PG@_DV
ACABLuukii420
Member List updated!
Ranks
[li]The Don-He is the most important man of the Family he can accept/kick/promote/demote every member[/li]
[li]Consigliere-As almost everyone know he is a person with the same control as The Don but he must obey Don's orders[/li]
[li]Underboss-He is almost the same thing like Con but he cant enter or take money from Family Valut[/li]
[li]Caporigieme-He has control of the Base/HQ except office it means that he has to open the door and close it when indeed he can control lower ranks[/li]
[li]Solider-He is a new member that gained the Family Staff's Trust[/li]
[li]Associate-He is the lowest and still untrusted member of Family[/li][/i][/b]
Family Rules
-rules are simple alllways follow the higher rank members orders unless they are against server rules or family rules
-allways help when someone asks for backup
-don't spam or insult group members
-don't use /rob or /rape to other members without higher rank as boss and underboss premission
-don't ask for promotion from the leaders
-don't ask for meeting The Don or The Godfather without taking appointment
-don't tell anything about the group to your friends or other players
-have nice behaviour
-be patient
-always use role play like calling the leaders Boss or Sir
-don't act like a thug
-You need to have 600+ score to join us
-you can join other groups
-if you got fail in test you may re-apply
-warnings:X,you make an X after your name in list it means that you are warned make X X X you will get kickes
Example:
[Lsrcr]Abdul.X
[Lsrcr]Abdul.XX
[Lsrcr]Abdul.XXX (instanly kicked)
Application Template
Code: Select all
In-Game name:
Score:
Proof of score:
Reason:
Secret Word:
Testing officer Template
Thank you for choosing Super Legends
Before you get accepted/denied we will make you a test wich includes Rules/RolePlay/Flying/Driving/Shooting.The minimum passing result of test is 3.5/5.if you result less than that you will get auto denied and the details:Rules part(you must know the rules perfectly.The minimum result of rules part is 4/5 if you get less you get auto denied)Flying(the minimum result of flying part is 3.5/5 if you get less you will get auto denied.The same with driving and shooting).So before Test please get prepared.Good Luck
Testing officers[TO.]
1.[Lsrcr]Abdul.[HTO.]
2. [Ls]Saeed [TO]
3. (None)
You can alos get tested by Don [li][Lsrcr]Inzane[/li][/i][/b][/color]
[li][Lsrcr]Sonit[/li][/i][/b][/color]
Code: Select all
[color=#804000][b]Thank you for choosing Super Legends
 Before you get accepted/denied we will make you a test wich includes Rules/RolePlay/Flying/Driving/Shooting.The minimum passing result of test is 3.5/5.if you result less than that you will get auto denied and the details:Rules part(you must know the rules perfectly.The minimum result of rules part is 4/5 if you get less you get auto denied)Roleplay(the minimum result of this test is 3.5 if you get less you will get auto denied)Flying(the minimum result of flying part is 3.5/5 if you get less you will get auto denied.The same with driving and shooting).So before Test please get prepared.Good Luck[/b][/color]
[color=#000080][b]Testing officers[/b][/color][color=#BF0000][b][TO.][/b][/color]
[b][i]1. [Lsrcr]Abdul. [HTO]
2. (None)
3. (None)
[/i][/b]
[color=#BFBF00][b]You can be tested by the leader [/b][/color][color=#0000BF][b][i][li]Drin09[/li][/i][/b][/color]
How should test be:
Code: Select all
[b][center][u]The Super Legends Test Results[/u][/b][/center]
[color=#BF8000]Rules:-/10
RolePlay:-/5
[u][b]Driving[/b][/u]
[b][u]Shooting[/u][/b]
S/O:-/10
M4:-/10[/color]
Good ways to get promotion
*If you want to get promoted please be active on forums
example:Make posts
be active in game
example:Stay with group members and make notifications for group
For every mission you finish you get a paycheck of 5000$
Leaving/Going Inactive?
If you going inactive please post in the correct format:
Code: Select all
[b][i]In-Game name:[/i][/b](Write here)
[b][i]Leaving date:[/i][/b](Write here)
[b][i]Date of comming back:[/i][/b](Write here)
[b][i]Reason:[/i][/b](Write here)
Someone of Family rob/rape/insult you???Report him with this Format
Code: Select all
[li]Your name :[/li]
[li]Rule Breaker name:[/li]
[li]Proof:[/li]
[li]Reason:[/li]
Want to be Training officer?
Code: Select all
[li]Your In-Game:[/li]
[li]Why you want to be Training Officer[/li]
Discord: swaka9
Drin
Drin
Post by Drin » November 11, 2014, 9:05 pm
man why did u stole my designs??????
Geographi
Geografi
Post by Geographi » November 12, 2014, 1:18 am
WE ARE NOT ALLOWED TO STOLE PAGATI RANKS!
Blizzard wrote:
Could you please not copy the ranks of pagati? Its one of the group rules.
MattDet wrote:
Well, Santa has now been banned for a year.
SAMP Name: Santa Claus
Ban Reason: constantly breaking rules
Type: temporary
Date: 23:59 UTC 12/9/2014
Unban date: 00:01 UTC 12/8/2015
Defense: I accidentally got myself placed on my own naughty list. Please unban me.
$niper
$niper
Post by $niper » November 12, 2014, 2:59 am
You cant copy the ranks of pagati . Its one of the group rules.
Made by
Dog.
Active Player.-Pagati Soldier.-TGOLS Chief Enforcer.-Saints Sergent.-SFC Rookie.-Dom Famiglia.-Stunt King.
Swaka
[Lsrcr]Swaka
Post by Swaka » November 12, 2014, 11:27 am
We didnt copy
Discord: swaka9
T_Rex
T_Rex
Post by T_Rex » November 12, 2014, 12:34 pm
Wut u mean by FUCK OFF?? o.O
By Faraon
Swaka
[Lsrcr]Swaka
Post by Swaka » November 12, 2014, 12:59 pm
Dude nvm
Discord: swaka9
7 posts Page 1 of 1
Return to “Unofficial Groups”
