Major change in job/skill commands
7 posts Page 1 of 1
Uziskull
Uziskull
Post by Uziskull » March 22, 2015, 10:52 pm
Your name: Uziskull
Suggestion headline: Changing some/most job/skill commands for items
Picture: -
Importance of suggestion: 3
Why should it be accepted: Given the amount of "useless" and/or underused items and weapons in the game, I suggest that some commands are changed over to item uses. I believe this is a good idea, since it would be more practical to point and use an item than to type the command in the chatbox, followed by the id of the player (that may sometimes be hard to see/do). It would also highly discourage the use of keybinds in a negative way (which are regularly used, despite obviously breaking rules), which would benefit all of the community. Of course this is a rough idea, and as such it will almost certainly be highly criticized by long-term players who are used to the chatbox command mechanic, but I personally think it would make the server a bit more balanced, especially towards newcomers who aren't used to writing the commands beforehand to then use them near the players.
Some examples would be replacing /rape [id] with a dildo, /rob [id] with a knife or /cure [id] or /heal [id] with a bouquet of flowers. You could also take a underused weapon and turn it into a command-only item: you could limit the amount of ammo a Desert Eagle could carry, lower its range and fire rate drastically, and use it as /taze [id].
I really believe this would make the server better in the long term, but this would require exhaustive testing and feedback from the community to confirm.
Gotix
Gotix
Post by Gotix » March 23, 2015, 10:02 pm
I agree with this but mostly with the replacement of the /taze command for a Desert Eagle with less range and firerate because it does help with the amount of people that use keybinds to instantly taze you and arrest you, because we all know how annoying that is. This would also, yes, give a use to some of the useless items that are rarely used like the Dildo (that is used often as a joke between friends to beat eachother with it because that IS fun between friends) and so give it the use of being the /rape command WHEN you are a rapist maybe but it'll also start annoying others if rapists just start swinging it around at everyone giving everyone chlamydia and what nots.
All in all, it's a good idea but that is up to the majority of people and staff like always :mrgreen:
Thursday Online
[Lsrcr]SlambeiY
Post by Thursday » March 24, 2015, 6:56 am
BIG -1
Credits: KikoLolo
Uziskull
Uziskull
Post by Uziskull » March 24, 2015, 10:54 am
[Lsrcr]Slam wrote:
BIG -1
You mind at least explaining your reasons for not approving this? It would make gameplay easier by avoiding the usage of the chatbox too much.
[Lsrcr]Yakuza
Yakuza
Post by [Lsrcr]Yakuza » March 24, 2015, 11:37 am
-1
I prefer the chat box
Click on the pic.
LS-RCR Donator | Tagged Member | S.W.A.T. Ex Commander | Top Active | Map Creator
Gotix
Gotix
Post by Gotix » March 24, 2015, 4:11 pm
[Lsrcr]Yakuza wrote:
-1
I'd like to know why you prefer the chatbox. Can you maybe use a macro faster than you can use a gun? Will that be your reason?
Just wondering.
Keenan
Keenan
Post by Keenan » March 25, 2015, 1:57 am
Macros are pointless on command that need an id, you would have to set the keybind to hit every id from 0-200. in which 199 of the time the command with fire will be wrong and will be logged in the server logs. Easiest way for an admin to differ from real skilled cuff and ar cops from keybinders.
7 posts Page 1 of 1
