Suggestion [Not approved]
If you have a new idea that could benefit the team, feel free to share it here!
10 posts Page 1 of 1
ZiadMohammed
ZiadMohamed
Post by ZiadMohammed » April 4, 2015, 11:15 am
In-Game Name: [Lsrcr]ZiadMohammed
Suggestion: Add new Command /Tazer id
Explanation: New Command For SWAT ONLY is /Tazer id --( /Tazer id and after he is auto-cuffed )How i'm/we Suppose to /Cuff 5 or 6 players in/on 1 car ?? even if we tried to kill them we will die and if we tried to /Taze /Cuff 2-3 off them the other will kill us. So, /Tazer id will help us when we use it after it its Auto-Cuff the player. + This New Command /Tazer id can only be used on this Case ( 5 or 6 on/in 1 car ) If any one Did it in any Case he can get WARN or Kick for it... There for if you are going to add this Suggestion add this Rule ( Your are not Allowed to use /Tazer id on 1-2 players Just on 5-6 players in 1 car )
Reason: As we all know now most off the players team with each other to cophunt SWAT - ARMY - COPS and they can be 5-6-7 and more and also they can be about 8-9-10 at LSA And killing its called ( Small riot ) so, As i said... how we/ Im suppose to /Taze /Cuff and /Drag 5-6 or more suspects ?? 100% i will die even if i cuffed 2-3 or killed 2-3 the other will kill me and SWAT Cannot use /Ar we must /Drag so, I Believe This Command will Help Us.
RiseOfTheDark
RiseOfTheDark
Post by RiseOfTheDark » April 4, 2015, 11:30 am
+1
but it has to have precise rules of using.
Regards, RiseOfTheDark.
OsamaAbouelhassan
Osama
Post by OsamaAbouelhassan » April 4, 2015, 11:54 am
too op and sometimes i type tazer instead of taze ... a small mistake could lead to some serious trouble .. Maybe my reasons aren't convincing but since cuffing will be useless because we can only drag one suspect per 2 or 4 seated vehicle (maybe /grab command will solve this) .. finally, I don't think it will change anything because breaking cuffs might be done and it's somehow impossible to defeat 5-6 suspects all shooting at you even if we have this command
ZiadMohammed
ZiadMohamed
Post by ZiadMohammed » April 4, 2015, 12:16 pm
we can easily change the command lol ? and yes this command will help us very much /grab won't make u cuff 5-6 suspect it will just make u drag 2 suspects
Hashish
Hashish
Post by Hashish » April 4, 2015, 2:13 pm
you can call backup from cops/army in any time
you can use rb / swat bomb
if u don't wanna drag or u see it's hard change skin to cop and ar all !!
and that's will be silly for swat because we are the best at soc
and i never see it's hard to fight 5 or 6 or more if u died u can come back and fight them again and again
that's why we are SWAT, right ?
-1
ZiadMohammed
ZiadMohamed
Post by ZiadMohammed » April 4, 2015, 2:29 pm
-1
if u are cop u can ar atleast 2-3-4 so, if u are swat u are going to ar ? U are going to drag and they will not leave u.
Why im suppose to change to cop to ar them Since we are best at soc ? Till now im sure this command will help us. Maybe ur right.
Hashish
Hashish
Post by Hashish » April 4, 2015, 6:55 pm
ur answer are mixed OMG
anyway u said they wont leave u then why we need that cmd lol !!
and u talking in case if u play solo .. where's ur team ? xd
Ritz
[Lsrcr]Ritz
Post by Ritz » April 9, 2015, 2:15 am
-1
Speed of commands is an important things in SWAT.So we cannot simply skipping commands using /taze and then /cuff with using /tazer.
Aamir
Aamir
Post by Aamir » April 17, 2015, 4:00 pm
-1
it is for 3 reasons
1. Many of the swat members will abuse this command that means they will always use tazer even if there is a single suspect..
2. It will effect our SOC (speed of commands) as using /taze then /cuff and then /deag is better which will improve but doing /tazer and then /drag will just decrease our speed
3. using /taze and then /cuff so b/w the time of this the suspect has an opportunity to run but if we use /tazer so there are no chances of running which can decline our interest
  • Aamir Vakeel
Thanks to Likewise for such a beautiful signature.
Image[url=steam://friends/add/'.76561198282576593.']Image[/url]
☆ | Proud Muslim | Proud Pakistani |☆
CresP
[Lsrcr]CresP
Post by CresP » May 1, 2015, 4:53 am
This is not solution. I recommend train more on commands or use strategies to kill/drag suspects.
Return to “S.W.A.T. || Suggestions”
