new item in 24/7
13 posts Page 1 of 2
Lil_Mister_Akill
Akill
Post by Lil_Mister_Akill » July 21, 2015, 7:59 pm
Your name: [Lsrcr]Akill
Suggestion headline: add a kind of small key or safety pin in 24/7
Picture: N/A
Importance of suggestion: 4/10
Why should it be accepted:
That suggestion would be great for criminals. A kind of key or safety pin in 24/7. Once you have it, it increases the probability to break cuff. It must be only one time used, as a razor.
Ik that swats won't like it, but it only increases the chance to /bc. Not 100% sure to be successful.
Proud Army Member
Sku11_Re10@ded
Sku11_Re10@ded
Post by Sku11_Re10@ded » July 21, 2015, 8:25 pm
Picture: N/A
i like it it +1
but if it was like the chance to breakcuffs are 65% for example and it can be used twice and shorten the /bc command delay a little bit that would be better right?
Lolmomlol
Lolmomlol
Post by Lolmomlol » July 21, 2015, 11:41 pm
i dont think it will be roleplayish, as when u are cuffed IRL, how could u get to the pin/key? like wtf? do u make ur hands magically taller and get to the key and use it? i will go neutral.. but more to -1
Vinny_Chenzo
Vinny_Chenzo
Post by Vinny_Chenzo » July 23, 2015, 5:35 am
+1
Paperclip or Bobby pin If it can happen in Hollywood it can happen in a game lol.
Aleksa
Aleksa
Post by Aleksa » July 23, 2015, 7:03 am
There's a trick where you can break the cuffs everytime when a cop cuffs you. It always works for me.
But, +1
as the /taze is OP and you can't escape that easily.(if it gets added, hopefully that will be added in /dweap as you spawn with wallet and cork, shoguns, so why not and this then? and admin packages) 8-)
Anaas
An44s
Post by Anaas » July 23, 2015, 8:42 am
+1
Immortal
[Lsrcr]Immortal
Post by Immortal » July 24, 2015, 3:57 pm
I dont think IRL you can escape in that way from cuffs. -1
Aleksa
Aleksa
Post by Aleksa » July 24, 2015, 4:25 pm
I don't either think you can pass by a guy and taze him out of nothing.
CriticaL
Critical
Post by CriticaL » July 24, 2015, 4:37 pm
What's this trick? I repurt u if u no say k?
OT: +1 please
Vinny_Chenzo
Vinny_Chenzo
Post by Vinny_Chenzo » July 24, 2015, 5:28 pm
^ I think it has something to do with using another commands while in the cuffs. Which causes the /bc to work right after I think it's a bug/bad coding. It resets the probability of getting out.
Just a speculation as I've never done this but one time. I was about to get thrown in jail.
I did /w then my message then tried /bc and voila escaped. But didn't have time to try again.
If this is true they need to fix this asap lol. And I better not get in trouble for mentioning this if I'm right cause again I have no clue and it may have been coincidence.
