DOCUMENT: S.W.A.T. CAREER GUIDE
LS-RCR SWAT GROUP
LS-RCR SWAT STAFF COMMAND TEAM
A Special Weapons and Tactics (SWAT) team is a designated law enforcement team, whose members are recruited, selected, trained, equipped and assigned to resolve critical incidents involving a threat to public safety which would otherwise exceed the capabilities of traditional law enforcement first responders and/or investigative units. SWAT is an accepted title for a team with specialized training and expertise as defined above and further defined within these standards.
S.W.A.T. Old Base Trailer
S.W.A.T. Weapon list
S.W.A.T. vehicle siren (Sultan & Bullet)
Note: You can turn on or turn off S.W.A.T. vehicle siren by using H button (horn key) on your keyboard.
Police Lights System
Note: - The /policelights system has been changed completely, allowing for players to /policelights [1-4]
- Police lights should destroy when the vehicle has been blown up or removed / reset.
- Different types of police lights:
- 1 = In car like the old /policelights used to be.
2 = Same light as the first one, but it's on top of the car roof like a portable police light - Like the ones they stick out of the window in movies.
3 = Bar light like the default police car lights
4 = Different styled bar light - similar to 3
S.W.A.T. Dispatcher
Note: Press F to view information.
S.W.A.T. Drone
The S.W.A.T Drone feature that's accessible for all members occupying Sergeant First class (SFC) and higher ranks. This feature requires two members in order to be launched. The first one (regardless of his rank) needs to be driving a car and to open the boot by typing /boot. The second member (only SFC+) should already have a drone on him, then he needs to load the drone by typing /swatdrone and launch it using the same command again. This feature has a 15 minutes cooldown which can be checked on /swcd.
Once the drone is deployed, you'll be able to see some stats on the left side of your screen that are meant to guide you through your drone usage, the drone gets automatically destructed after 30 seconds or if the base distance reaches 400.00m.
S.W.A.T. Shock Bomb
S.W.A.T. Bomb DetonatorNote: You need Specialist (SPC) rank to unlock the S.W.A.T. shock bomb feature. To take the bomb press F near table.
Here is S.W.A.T. Roadblock & Bomb Use and Tips viewtopic.php?f=153&t=23005
S.W.A.T. Items Depot
S.W.A.T. Items list
S.W.A.T. Roadblock
Note: You need Private I (PVT) rank you unlock the roadblock feature. To place roadblock use command /rb ,to remove roadblock use command /drb
For more information regarding roadblock usage read this guide: S.W.A.T. Roadblock & Bomb Use and Tips viewtopic.php?f=153&t=23005
S.W.A.T. Sprunk machine
Note: To use Sprunk machine ,press F near it.
S.W.A.T. Helicopter landing platform
S.W.A.T. Left Side Garage:
S.W.A.T. Right Side Garage:
S.W.A.T. Siren
Note: To enable/disable press H (horn) button on your keyboard.
Spawning as S.W.A.T. member information
Note: You (From PVT rank) will spawn with 10 injections and 8 cuffs. To restock cuffs go to nearest S.A. Police Department, S.W.A.T. or Army base. Also you can restock your cuffs by entering S.W.A.T. vehicle.
To use injection write command /inject [amount]
S.W.A.T. Lift to main base #1
S.W.A.T. Lift to Sewers & Exit #2
S.W.A.T. Sewers Garage
Note: 2 Sultan vehicles, 2 FBI trucks, 2 Sanchez, 1 Enforcer & 4 boats.
S.W.A.T. Sewers Garage: Coastguard Boats
Note: 2 Coastguard boats.
S.W.A.T. Sewers Garage: Dinghy Boats
Note: 2 Dinghy boats.
S.W.A.T. Sewers Garage: Bikes Sanchez
Note: 2 Sanchez bikes.
S.W.A.T. Sewers Exit
Note: The gates will open automatically. To exit from Sewers to base, use same lift as entered to sewers.
S.W.A.T. Vehicle reset command
All the ranks starting from Recruit (RCT) can use this command.
To use reset SWAT vehicle feature type /swatreset[/i]
S.W.A.T. hide a markers
Note: You need Sergeant (SGT) rank to unlock markers hiding feature.
To use hide markers feature type /smh
S.W.A.T. tires and NOS
Note: /swvm can be used by PVT+ and can only be used by a vehicle driver. For 1 minute, every 10 seconds or so the vehicles tires will be re-inflated and the car will be provided unlimited NOS while the modifications are active. The cooldown is 5 minutes
To use this feature type /swvm
S.W.A.T. Personal vehicle
Note: Vehicles towed in S.W.A.T. skin can automatically be used by any S.W.A.T. member and will also replenish cuffs. This feature can be used by Private I (PVT)+.
S.W.A.T. Command to climb buildings
Note: /swclimb - can be used by SPC+ and you need to be close to the building with certain height to use this command.
S.W.A.T. Command to slip down buildings & from Maverick helicopters
Note: /swrope - can be used by SPC+ and you need to be on the edge of the building with certain height to use this command.
S.W.A.T. Dive
Note: At least one member must be standing at one of these two checkpoint to perform the command. What the command does is basically, if one of the members does /swatdive <id> with another member (when they both are on the checkpoints), they'll both be transported to one of the bases with a parachute. It can only be done with 2 at once, but you can do the command in groups! (like for example, let's say there are 6 members online, they'd form 3 groups and each one of them has 2 members. The 2 members of a group would stand on one of the checkpoints, then one of them would do "/swatdive <id>" and the 2 will be transported to the other base that we have. Then, another group would stand at the 2 checkpoints and then do "/swatdive <id>" after the other group is transported and they'd fly over the other base (and then repeat the same thing with the other group). Recruits (RCT) can not use this command however if there's a higher rank than RCT that wants to do the command with another RCT, it's possible (i.e RCT > RCT is impossible, but RCT > PVT is possible). The command has a 5 minutes cool-down, so you can't do it repeatedly! The command isn't really a big change in game-play, but it's fun to do with your teammate and overall generally provides a fun experience (and it's also good for pictures).
To use this feature type /swatdive id
S.W.A.T. command for SWAT cuffs
Note: When you cuff a suspect, you can decide whether you want others LEOs be able to arrest him/her or not by using /swar command. It works for each individual, for example if you cuff a suspect and type /swar command to allow LEOS to arrest, other members cannot disable it by typing /swar.
S.W.A.T. command for available commands list
Note: Type /swcd whilst in-skin to check what S.W.A.T. special commands are available.
Last Updated: 29/01/2025 - GrandSigned,
S.W.A.T. Commander Team
