[Lsrcr]Robin wrote:Yatsuga Application:Thank you for applying. Next step is test. You have 7 days to get tested by our testers. If you see any of them online, send them a /pm. The test has 4 parts: Knowledge of Yatsuga rules, Driving, Shooting, Location Knowledge. You will get points based on your skills shown in the test. After the test is done, the tester will upload results to forum and members will vote with positive, if they want you to be accepted, or negative, if they don't want you to get accepted. Keep in mind that you will get auto-denied if you: Don't get tested, get less than 3 in rules. Finally, after the members have voted, Boss will make final decision, will you get accepted or get denied. Good Luck
Server Name: [Lsrcr]Robin
Forum Name: [Lsrcr]Robin
Score (200+): 3.390+
Rob Rank: 540+
Reason: Yeay I am the first applicant! Anyways, I am not that active as a robber, I think Yatsuga can change that for me.
BLAVOR
