Radio/Location conflicting
7 posts Page 1 of 1
ShItBrIx
shitbrix
Post by ShItBrIx » February 3, 2016, 6:56 pm
Your name: Shitbrix
Suggestion headline: Radio/Location conflicting
Importance of suggestion: 10/10
Why should it be accepted: When you listen to /Radio, the track that is played at the moment is displayed on the Lower Left corner, but in the same place it shows the Location of where you are, which blocks the name of the track/author listed by the radio.
I suggest adding a command in /setup that lets you remove the Location text or move the Radio information elsewhere.
1%-er Biker - Bank Robber, Breakout King, Female Officer Kidnapper
Proud owner of a Freeway, Sabre and FCR-900
Proud user of Pump Shotties and AK-47s
Post by Robin » February 3, 2016, 7:08 pm
The text of the music is SA-MP default and can not be changed.
The location however can be moved to somewhere else, or just a bit up.
Zoroark
Zoroark
Post by Zoroark » February 4, 2016, 5:24 am
I want it moved just under the map. I've been wanting to suggest this ever since I started using the radio but I thought it was all samp and nothing LSRCR could do. Also kept forgetting to ask you about it in game.
MattDet
Matt
Post by MattDet » February 4, 2016, 1:38 pm
I would like to see the location moved to the top center of the screen or if that doesn't work then bottom center.
#TeamPopplio
signatureImage
MattDet wrote:
[Lsrcr]BomB wrote:
Useless topics as always .. ;3
Not till you download Crewspeak.
Lolmomlol
Lolmomlol
Post by Lolmomlol » February 4, 2016, 1:59 pm
you can just press Tab, the location will be gone and you can see the name of the song #EzPzLimonSquiz
ShItBrIx
shitbrix
Post by ShItBrIx » February 4, 2016, 2:17 pm
Ah. Good tip.
Vinny_Chenzo
Vinny_Chenzo
Post by Vinny_Chenzo » February 7, 2016, 5:35 pm
7 posts Page 1 of 1
