122policeofficer wrote: I also think this will get some advantages for criminals becasue for aiming you need to have some skills.I like the idea and all, but this I disagree with. Do you really think that aiming a 9mm taser gun is that hard? If you compare a taser with ridiculous range to a /taze command with a 2-meter one, criminals have better chances of escaping with the latter. Why? The /taze command seems fairer because cops would have to run and keep up with the suspect rather than just aiming leisurely from a distance. The only advantage of this idea is that cops can't taze right away after barell rolling out of a car. And with a 9mm gun, you can taze a suspect while he's inside a vehicle. I also don't know if it can be scripted so that the taze effect only works on criminals, because if not... well, just imagine cops tazing everybody in town. So yeah, unless you can somehow decrease the range, limit the ammo, script it to only work with wanteds and make criminals immune to tazing when they're inside a car, my vote will remain -1.
Cheese wrote:It's scriptable...I saw this on one server at YT.Current taze range is allright and it should stay remain as that if we add taser gun.Yeah tazering in car is aviable,but of course I am not suggesting that,I am suggestin while suspect is on foot,and I think we don't need tazering suspect in car for now!122policeofficer wrote: I also think this will get some advantages for criminals becasue for aiming you need to have some skills.I like the idea and all, but this I disagree with. Do you really think that aiming a 9mm taser gun is that hard? If you compare a taser with ridiculous range to a /taze command with a 2-meter one, criminals have better chances of escaping with the latter. Why? The /taze command seems fairer because cops would have to run and keep up with the suspect rather than just aiming leisurely from a distance. The only advantage of this idea is that cops can't taze right away after barell rolling out of a car. And with a 9mm gun, you can taze a suspect while he's inside a vehicle. I also don't know if it can be scripted so that the taze effect only works on criminals, because if not... well, just imagine cops tazing everybody in town. So yeah, unless you can somehow decrease the range, limit the ammo, script it to only work with wanteds and make criminals immune to tazing when they're inside a car, my vote will remain -1.
Kaosx234 wrote:Only if taser time is 5sec minimum.
[Lsrcr]Mega115 wrote:It would be hard to taze people with high ping and lag. -1I think we could add that you can shot taser like bullets,so if you miss it once,you automaticly get taser reload so you don't get problems with lagers
