Drastic wrote:I don't see any HDDs in that setup. Are you planning to add them later or use the ones that you currently have?Good thing you mentioned it. In-case anyone was interested, I already have my peripherals from my current build, and plan to just take my 500GB SSD and 1TB HDD and place them into my new build.
Also, I'd personally go for a 1070 since it comes at a better price point and hey, we can always add another one down the line and still have a relatively decent setup.
Fatal wrote:Great. Do post pictures once you're done with the setup.Drastic wrote:I don't see any HDDs in that setup. Are you planning to add them later or use the ones that you currently have?Good thing you mentioned it. In-case anyone was interested, I already have my peripherals from my current build, and plan to just take my 500GB SSD and 1TB HDD and place them into my new build.
Drastic wrote:I plan to post pictures! And yeah I know what you mean. As I'm sure you can see, my theme is white. White case, white MOBA. Tried to find white RAM sticks but I love the ones I currently have. The factory model of the 1080 is white, but its 120$ more and it's not overclocked to 1.721GHz. It's only 1.61GHz. I'm also getting aftermarket fans with white LED's, and some LED strips to go alongside the base of the case.Fatal wrote:Great. Do post pictures once you're done with the setup.Drastic wrote:I don't see any HDDs in that setup. Are you planning to add them later or use the ones that you currently have?Good thing you mentioned it. In-case anyone was interested, I already have my peripherals from my current build, and plan to just take my 500GB SSD and 1TB HDD and place them into my new build.
Also, I so wish they would let us pick the accent on the graphic card. I can see that you're going with a black and white theme but you don't have much of a choice regarding the graphic card and are stuck with that red-ish accent.
