You are permanently banned from this server - Bug
Bug reports that are very old and may or may not still be valid with the current state of the server.
Hammad13
Hammad13
Post by Hammad13 » September 21, 2016, 3:00 pm
I'm having this issue for 3-4 months and I don't want to get banned by using a VPN.
See this:
http://imgur.com/a/h7DPY
Post by Astrl » September 30, 2016, 7:36 pm
This isn't an Lsrcr bug that is caused on our end. This was also posted in another topic seperate to this one that I just closed.
As I previously said,
Does it show up with the "You are banned from this server." string?
That's a SA-MP sided bug and isn't our fault / problem with the server, It's caused by high ping / unstable connections to the server.
It also happens when you restart some SA-MP servers, it's more annoying than anything else, just /q and rejoin the server and it's sorted usually :P Sometimes you'll need to close your SA-MP also.
If this happens persistently please try and sort your internet stability out and check for packet loss, this may cause timeouts and stuff.
Topic locked as this is not a bug that's related to Lsrcr's SA-MP server, this is a bug that is due to your own connection.
Return to “Stale Reports”
