knifeboss1557 wrote:Your Name: KnifeBoss
Your suggestion: Remove the fail drag from houses.
Reason:This fail drag doesnt even do anything except taking our time.Even its not rpish and as we cuff a suspect and try to drag him some other leo can simply come to us and arrest him.i dont see a reason why this feature was added and would be better removed.
knifeboss1557 wrote: Your Name: KnifeBoss
Your suggestion:Allowing 1 player to use swatdive cmd
Reason:It would be better of if we could use the swatdive on ouselfs for example /swatdive (your id).If you decide to add this feature dont remove the 2 player swatdive also since its useful when you are with a pvt but whats bad when you are the only swat in skin and need to go to lv/ls you cant do it alone unles going to ls/lv by a vehicle or killing yourself.
