Rally3 wrote:-1.As i said it's a blackmarket item or donor item i don't think someone with score 1500 will use cheats even if he used it like aimboot or no scroller etc... u won't know with the map marker and it's just 30 second not alot of time i guess .
Player blips help to see if a player is cheating or whatnot. Yes, swat members may cheat too with /smh but the function is limited in quantity, and it is supposed that only experienced members have access to swat, let alone /smh.
No need to fix what already works, sorry.
[Lsrcr]Karthik wrote:He can't rob bank in 30 seconds ofc...The item would be activated when the criminal use the command so if used it when i get out of the bank 30 second would be good
[Lsrcr]Karthik wrote:Thanks for your opinionxGTr wrote:ah okay then, but still NEGATIVE[Lsrcr]Karthik wrote:He can't rob bank in 30 seconds ofc...The item would be activated when the criminal use the command so if used it when i get out of the bank 30 second would be good
xGTr wrote:Rally3 wrote:-1.As i said it's a blackmarket item or donor item i don't think someone with score 1500 will use cheats even if he used it like aimboot or no scroller etc... u won't know with the map marker and it's just 30 second not alot of time i guess .
