Windows problem
16 posts Page 1 of 2
Jed
Jed
Post by Jed » April 1, 2017, 5:22 pm
So,here's the story.I installed a copy of windows 7 64bit yesterday and after I finished I tried to connect to internet but failed.After that I shut down my pc but it wouldn't shut down so I just unplugged it.Today I turned it on again and the pc turned on but the monitor didnt show anything.So I need help,thanks
No pain no gain,100% nečural
Raskit
Raskit
Post by Raskit » April 1, 2017, 5:47 pm
why would you just unplug the PC while it was running
Rally3
[2F2F]jimmyfallon
Post by Rally3 » April 1, 2017, 6:40 pm
If u did a clean install after formatting the entire HD, you will need to install your network drivers to be able to connect.
Download them on some other machine, re-install windows again, and once the installation is done plug the usb in and install the drivers, then you should be able to connect.
Vendetta
Vendetta
Post by Vendetta » April 1, 2017, 7:59 pm
Raskit is right you shouldn't have done that if the shutdown key is not working use this command in the future type it in the cmd
shutdown -s -t 1
And for your internet did you install the internet drivers? if you didn't make sure to download them using another PC/laptop.
IceBilizard
IceBlizzard
Post by IceBilizard » April 2, 2017, 8:33 am
Windows 7 64 or 32bit did not require any net driver i am using internet without driver in my pc i am using Windows 7 32bit and the problem is because of not installed windows properly or there are any file(s) in the PC which creating problem in your computer try to re-install fresh copy and find any anti-virus and scan your computer.
Jed
Jed
Post by Jed » April 2, 2017, 5:08 pm
So I still cant boot up my PC...what should I do?Reinstall using USB or try to boot up?
Raskit
Raskit
Post by Raskit » April 2, 2017, 5:11 pm
Do you hear any beeps when you try to boot up the PC?
Any sign of life, any lights etc?
Jed
Jed
Post by Jed » April 2, 2017, 6:01 pm
Yes,its fine,even the CD Driver opens up on button.
But the monitor doesn't show anything even tho it's working.
I tried connecting to the TV too with the cable but nothing shows up.
I searched on internet for an answer and they all said "gpu isnt working,motherboard isnt working" etc,but I dont believe thats the issue
Raskit
Raskit
Post by Raskit » April 2, 2017, 6:28 pm
Plug the video input directly into the motherboard and see what happens
Jed
Jed
Post by Jed » April 2, 2017, 7:36 pm
Nothing happened
Return to “Tech Talk”
