Rally3 wrote:I suspected that was the issue, since one time mine fucked up and I had the same problem (in Windows) where I couldn't get it to even show up on "Disk Management".I've got both a Windows machine and an iMac, both devices can't use the drive properly.
Try to run a VM on any sort of Linux distro, that's how I got mine to be able to "come to life" again, then formatted on NTFS. Guessing your issue is on Mac OS, but at least on my end it recognizes the "NTFS" partition just fine.
I tried Ubuntu, Fedora, Parrot OS, and others.
Robin wrote:fairly easy to do, get oracle virtualbox (free) download a live iso (i suggest a "full" iso to see linux for yourself) and check gpartition or whatever it was calledRally3 wrote:I suspected that was the issue, since one time mine fucked up and I had the same problem (in Windows) where I couldn't get it to even show up on "Disk Management".I've got both a Windows machine and an iMac, both devices can't use the drive properly.
Any way to do this without a Linux VM?
Rally3 wrote:I'm unknown with Linux, mind helping me with the batch (or shell cmd whatever it is, sudo or something?).Robin wrote:fairly easy to do, get oracle virtualbox (free) download a live iso (i suggest a "full" iso to see linux for yourself) and check gpartition or whatever it was calledRally3 wrote:I suspected that was the issue, since one time mine fucked up and I had the same problem (in Windows) where I couldn't get it to even show up on "Disk Management".I've got both a Windows machine and an iMac, both devices can't use the drive properly.
MichL1337 wrote:Fix Windows was unable to complete the format error with Windows Disk ManagementAlready did that, didn't work...
When you get 'Windows was unable to complete the format' error message, you can first try to fix this problem with Windows Disk Management tool. All you need to do is to follow this path:
Step 1. Right-click the "My Computer" icon on the desktop and hit the "Manage" option. Click on "Disk management" to open Windows Disk Management.
Step 2. Select the Micro SD card, USB or flash drive that you need to format, right-click and hit "Format". If there are any partitions on the drive, you should delete them all at first.
