Criminal wrote:The question should not be asked over here as per the topic i want to ask that if any of the army member /su(ed) a suspect can every other army member eliminate him wothout /su ? If they can so make the same rule for the swaties. If they can't im going with +1.I wanted to add to the suggestion that all S.W.A.T. and Army members should get a message when a fellow team mate asks a suspect to surrender, has both it's up and downsides
Robin wrote:You got me, Better then this there should be command like /sulist so an army/swat member can check who is already got sued sometimes chasing a suspect remove your concentration from the main chat.Criminal wrote:The question should not be asked over here as per the topic i want to ask that if any of the army member /su(ed) a suspect can every other army member eliminate him wothout /su ? If they can so make the same rule for the swaties. If they can't im going with +1.I wanted to add to the suggestion that all S.W.A.T. and Army members should get a message when a fellow team mate asks a suspect to surrender, has both it's up and downsides
