Allowpm.
7 posts Page 1 of 1
Zeyad_Mafia
xSupreme
Post by Zeyad_Mafia » July 9, 2017, 6:29 pm
Your name: Zeyad_Mafia
Suggestion headline: Add a command for telling your friend to allowpm, We can make the command /c (id) or /ca (id)
Importance of suggestion: 6.5/10
Why should it be accepted: Instead of flood the chat with "hey you, allowpm" "pmon for a sec" "allowpm plz"
We can use /c or /ca (id), since /call command already added and not useful. after using it, the player u called will receive a message saying
"(caller name) has called you, /allowpm (id) to respond.
Also, we will have to make a 3-5 mins cooldown before use it on the same id again, to avoid spammers & abusers.
(P.S: U can use the command only on players disabled the PMs).
Flying solo like a eagle, Walking alone like a wolf.
[Lsrcr]Invincible
[IND]Invincible
Post by [Lsrcr]Invincible » July 9, 2017, 6:33 pm
then what's the point of blocking pms, You block pms when you are busy and don't wanna receive pms or you are not in a situation to respond to.
This can be improved by, when someone tries to /pm someone for first time, the receiptant gets notified (with grey msg barely can be seen) with player sound. like 'this person tried to pm you, /allowpm to accept pms from him'.
Just like when you use /putnitro [id] and the ID player gets notified about Offered you to install nitros, /request mechanic to accept.
Zeyad_Mafia
xSupreme
Post by Zeyad_Mafia » July 9, 2017, 7:26 pm
That will be fine too.
Post by Robin » July 9, 2017, 8:07 pm
-1, just ask over the mainchat.
People pmoff to avoid getting spammed, they'll just get spammed with this instead.
Mr.Nightmare
Knight
Pagati Underboss
Post by Mr.Nightmare » July 9, 2017, 9:44 pm
Zeyad_Mafia
xSupreme
Post by Zeyad_Mafia » July 9, 2017, 9:59 pm
That's why i said "add 3-5 mins cooldown before using it again."
Post by Astrl » July 16, 2017, 11:05 am
Suggestion denied for this reason.
7 posts Page 1 of 1
Return to “Rejected”
