Many robot space ships have actually disappeared while they were taken off earth for exploring. The radar can't get their signal and the only way is for them to run into a black hole. But, if they get stuck there, will it ever disappear? If no, than that black hole would not be with nothing anymore, but with metal, gas and other space ships materials.There's no way for a black hole to be the reason for these disappearances. A Swarzchild black hole is formed when a start having mass above the Chandrashekar limit to run out of fuel (from nuclear fusion) and implode due to the immense gravity of the mass. However, there are two possibilities, either it'd become a black hole or a neutron star. Besides, there are supermassive black holes which lie at the center of every galaxies. Every object has a Swarzchild radius, ie the radius we would have to be shrinked to in order to become a black hole. The Swarzchild radius is so low that you have to compress the entire mass (weight) of the earth into the size of a peanut in order for it to become a black hole. So, if there was a black hole anywhere near us where a space craft can ever reach, we're fucked. Black holes are called black holes because the orbital speed of the black hole at the event horizon is equal to the speed of light so you'll need something faster than the speed of light to orbit the black hole or return from it but nothing can travel faster than light so even light can't escape. Even if the sun turned into a black hole after it's death (which won't happen), nothing would happen to the orbits of the planets revolving around it. Except that the sun would be so small to view from earth and light doesn't escape a black hole.
Isn't this a bit weird though? The space ships weren't too far away from earth, before they got dragged into the black hole. Is there a possibility that the whole earth falls into a black hole where there is nothing. Would we be able to survive?
Of course not, the speed that black holes pull us, we'd all crash onto each other and something and explode to pieces in less than a second, we would feel it at all, we'd all just disappear, but earth might not, we have a long journey to be stuck on the middle and by that time, everyone is dead for sure.
[Lsrcr]Oggy wrote:Spoiler: show
GalaxyGeri wrote:So as far as i understood, you'd say that the space ship would take the advantage of the black whole to get out of it, when the gravity gets you lose to the horizon. Its a good idea, but I think i'd take large calculations to realize if we can do that or not, if we can go that far for the black hole to not attract the space ship again, I think its not possible with the speed of our space ships, well yet.Gravity slingshot technologies allow us to get proves up to one forth the speed of light, according to a NASA statement earlier this year (can't confirm, pretty sure it matches their statement).
If you would open a hole in between the whole world which starts from a place and ends on the other side and you'd fall, what would happen? Well, you'd die because of the heat obviously, but if an object was, he'd go close to the other side, but it would stop immediately, because the center of the earth would attract it on a very large power.
So, till the middle of the earth, the object would be raising speed, but once it passes it, it would start lowering it, because of the gravity. So, it would fall back and so on, till it gets stuck in the middle.
Earths gravity is way lower than a black hole and its unsure whether you can or cannot have the much power to get out of its gravity, by getting the advantage of the gravity it self.
However, there is another issue.
What if the gravity is so strong, that we don't only lose our consciousness, but probably explode. The body would most so fast forward, that our blood would smash really hard on our legs which would make our whole body explode and therefor die. We don't know, but this is a huge issue.
Users browsing this forum: Baidu [Spider] and 1 guest
