Skillzz wrote:Robin wrote:As I said, this has to do with the class selection LS-RCR uses, the one from the pic is the SA-MP default and is shitty once you got about 200 skins and 7 classes to pick from.
LS-RCR uses the a modified mSelection version of the class selection which is the cause of this.
TL;DR: There's no fix.
As Robin said, there's no fix to this problem as we're using the mSelection method of displaying the skins.
If you're bugged just /reconnect yourself or log out then back in again - It's annoying I know but it's alot easier than displaying 200 different skins and all the classes separately like the other methods.
Skillzz wrote:Has been reported, it's not fixable unfortunately.A fix has finally been implemented (thx to hiresh for identifying it). If it still occurs, try updating your SA-MP version.
