Indognito wrote:Suggestion 1: no regardless if they are driving them or not it should be despawned, it’s annoying but keeps the streets clean from those cars, by allowing command like this will cause more cluttered cars on the streets and might cause vehicle despawn bugs.Pretty much what Indog said ^
Suggestion 2: not scriptable and if it is it’s useless to add since it’ll not get used, if you don’t want a certain weapon use /disarm current
Suggestion 3: since this is similar as suggestion 2 the same answer will be given, it’s useless and a waste of time to script.
| [center][img]https://i.imgur.com/sQBU8SP.png[/img][/center] | [center][img]http://i.imgur.com/ofO0Cur.jpg[/img][/center] [size=150][center][b][color=#0E316D]LSPD United Staff Member & Instructor[/color][/b] [color=#00FFFF][b]S.W.A.T. Master Sergeant[/b][/color][/size][/center] |
| [youtube]bkFxhTVb6eU[/youtube] | [img]https://media.giphy.com/media/HuNH9ntgLtWKI/giphy.gif[/img] |
Jordan wrote:2: You can actually press F to hide your weapon.F is used to exit the car
xDeadlyKiller wrote:When you're holding weapon as passenger(H) and press F it exists H state and you're passenger who's not shooting.Jordan wrote:2: You can actually press F to hide your weapon.F is used to exit the car
(Could be the driver or a passenger)
ackman wrote: or turn off /engine to prevent Admin smart vehicle reset?Only players who need this necessarily will use it. It's like you give a warn to the players before you reset.
Indognito wrote: Suggestion 2: not scriptable and if it is it’s useless to add since it’ll not get used, if you don’t want a certain weapon use /disarm currentIn case you don't want to disarm your weapon?
Yes, Its scriptable.
Indognito wrote: Suggestion 3: since this is similar as suggestion 2 the same answer will be given, it’s useless and a waste of time to script.About if its scriptable or not, Yes, It can be scripted because i have got this idea from a popular RP server. Actually i liked the idea and wanted to share it with you guys to think of it.
ackman wrote: Negative on other two because it's semi-rpish server.Lsrcr server is a semi-rpish server but we still can use it. It can be used for RP purposes as we have RP groups for crminals and Cops. also as we see nowadays many of criminals like to cophunt in sultan with 3 mechs and 1 weapon dealer. They sometimes get confusion when they are being chased by swats, cops or armies and they might forget to switch to m4 to shoot. So, they don't have to stop the vehicle then switch. They can easily switch and hide the weapons while being in car and just typing commands without needing to get out of the car then into it again. We got a pre-typres who can arrest a criminal in 1-2 secs. So, Its risky to get out of the car and then into it.
Be_Quiet wrote:I understand what you’re saying and I’m not -1 because I don’t like suggestion 1, Players should not have access to vehicle spawner tools period, they (regardless if they’re in groups or not) cannot be trusted with stuff like that. Besides it’ll cause too many cars to not get despawned.Indognito wrote:Suggestion 1: no regardless if they are driving them or not it should be despawned, it’s annoying but keeps the streets clean from those cars, by allowing command like this will cause more cluttered cars on the streets and might cause vehicle despawn bugs.ackman wrote: or turn off /engine to prevent Admin smart vehicle reset?Only players who need this necessarily will use it. It's like you give a warn to the players before you reset.
So, They will /stoprespawn and their cars will not be respawned. Just in case you are cophunting and left your car to fight with someone but suddenly someone in your group/faction forgot to tell that he will reset and had resetted the cars without telling you so, You will need to get another car/bike and it might just end you getting arrested in alcatraz. They just can type an easy command that will prevent from their cars from getting respawned. I'm not saying that we will just not let other cars, bikes, planes etc from getting respawned, It's simply that if you don't want your vehicle from getting resetted while an admin+ or a member in group resets the vehicles, You'll need to use this command. It will not waste the player's time of searching for another vehicle because he just has forgotten to enter his car before the reset, Also if the player wants his vehicle to be respawned again, /respawn.
I hope you get what i mean.Indognito wrote: Suggestion 2: not scriptable and if it is it’s useless to add since it’ll not get used, if you don’t want a certain weapon use /disarm currentIn case you don't want to disarm your weapon?
I'm talking about switching it while already sitting in a vehicleIndognito wrote: Suggestion 3: since this is similar as suggestion 2 the same answer will be given, it’s useless and a waste of time to script.About if its scriptable or not, Yes, It can be scripted because i have got this idea from a popular RP server. Actually i liked the idea and wanted to share it with you guys to think of it.ackman wrote: Negative on other two because it's semi-rpish server.Lsrcr server is a semi-rpish server but we still can use it. It can be used for RP purposes as we have RP groups for crminals and Cops. also as we see nowadays many of criminals like to cophunt in sultan with 3 mechs and 1 weapon dealer. They sometimes get confusion when they are being chased by swats, cops or armies and they might forget to switch to m4 to shoot. So, they don't have to stop the vehicle then switch. They can easily switch and hide the weapons while being in car and just typing commands without needing to get out of the car then into it again. We got a pre-typres who can arrest a criminal in 1-2 secs. So, Its risky to get out of the car and then into it.
Not only criminals will use it but cops may also do, Like teaming with another cop while sitting the passenger seat, If you are in a chase with some criminals but you got confused and forgot to switch to m4, You will just switch it while sitting in a vehicle "While RP'ing"
