Indognito wrote:The best way to do this would be make it a mini mission where you get a certain amount of product, deliver it to the drug house and go back to the stash point to get some more, which the stash point would be in a secluded area and usually hidden in an abandoned car that’s in bad condition but the engine will be able to run good enough to get you from point a to point b. It sounds interesting but mainly due to it being rpish.You mean same as how trucking works? Yes this can be done, you might get fail sometime while stealing the truck and once you get into truck the red checkpoint will occur at the group base which you are representing that time and then you have to place the truck in that checkpoint and the depot will get filled witch certain amount of drugs (obviously depends on the staff) or it can be done as the weapon wrack robbery.
Criminal wrote:Indognito wrote:The best way to do this would be make it a mini mission where you get a certain amount of product, deliver it to the drug house and go back to the stash point to get some more, which the stash point would be in a secluded area and usually hidden in an abandoned car that’s in bad condition but the engine will be able to run good enough to get you from point a to point b. It sounds interesting but mainly due to it being rpish.You mean same as how trucking works? Yes this can be done, you might get fail sometime while stealing the truck and once you get into truck the red checkpoint will occur at the group base which you are representing that time and then you have to place the truck in that checkpoint and the depot will get filled witch certain amount of drugs (obviously depends on the staff) or it can be done as the weapon wrack robbery.
Indognito wrote:Oh yes. But we need this.Criminal wrote:Indognito wrote:The best way to do this would be make it a mini mission where you get a certain amount of product, deliver it to the drug house and go back to the stash point to get some more, which the stash point would be in a secluded area and usually hidden in an abandoned car that’s in bad condition but the engine will be able to run good enough to get you from point a to point b. It sounds interesting but mainly due to it being rpish.You mean same as how trucking works? Yes this can be done, you might get fail sometime while stealing the truck and once you get into truck the red checkpoint will occur at the group base which you are representing that time and then you have to place the truck in that checkpoint and the depot will get filled witch certain amount of drugs (obviously depends on the staff) or it can be done as the weapon wrack robbery.
Not exactly the same as trucking as trucking because the stash is already in the car the first time, though when you’re out of supply that’s when you would have to go back to the location to resupply, if it’s done the same way the weapon rack is it’ll get a little too tedious besides you would want to change it up since getting drugs won’t be the same as getting guns so the method would be different as well as the procedure to circumvent attention from law enforcement. It’s an attempt to keep things interesting as well as rpish.
