Shahan Online
Kawish wrote:It's better to bring old bomb back cuz this bomb is completely useless against cophunters in sultan with 10+ MechanicsEven though the way he said things wasnt perfect but every bit of it was hella true. There are about 10 criminals together and 9 of them being mechanics along with taze reflectors, swat bomb jammers, shocks, cop bat, cuff picks, cuff kit etc. Even if 5 SWATS follow them in a car they will still explode your car and you wont be able to do shit to them ( cause duh - 9 mechanics ). I am not saying relying on the swat bomb completely is correct but without the old swat bomb criminals have a huge upper hand. I have seen criminals escaping many swats even with the swat bombs and by using jsb (which was perfectly balanced).+ criminals have been buffed by allowing them to shock while cuffed and run while cuffed so its extremely hard to finish a cophunt with many members. Therefore, I suggest bringing the old swat bomb back. Cause as I have seen in the past few days, swatties prefer going in cop skin to finish the cophunts rather than swat skin (which used to be the opposite earlier).
bring it back and do some changes like it won't detonate if you die if it's possible or increase the damage to player who explode it, criminals already got shocks, taze reflectors so this bomb is useless i don't know why you guys removed it Criminals already have swat bomb jammer and we also got damage after detonating, now swat bomb removed they'll cry with tank, tank id op bla bla bla, it would be better to bring old bomb back.
Playa wrote:Yes, I'm totally agree with you. Bring back old swat bomb and make a rule like You can't Kill a wanted suspect If he is doing cophunt alone (Solo). We can't do anything with this new shock bomb. I've seen a lot of swat member's change their skin when the Cop hunters are hunting them. It would be better guys if you bring back the old swat bomb.Kawish wrote:It's better to bring old bomb back cuz this bomb is completely useless against cophunters in sultan with 10+ MechanicsEven though the way he said things wasnt perfect but every bit of it was hella true. There are about 10 criminals together and 9 of them being mechanics along with taze reflectors, swat bomb jammers, shocks, cop bat, cuff picks, cuff kit etc. Even if 5 SWATS follow them in a car they will still explode your car and you wont be able to do shit to them ( cause duh - 9 mechanics ). I am not saying relying on the swat bomb completely is correct but without the old swat bomb criminals have a huge upper hand. I have seen criminals escaping many swats even with the swat bombs and by using jsb (which was perfectly balanced).+ criminals have been buffed by allowing them to shock while cuffed and run while cuffed so its extremely hard to finish a cophunt with many members. Therefore, I suggest bringing the old swat bomb back. Cause as I have seen in the past few days, swatties prefer going in cop skin to finish the cophunts rather than swat skin (which used to be the opposite earlier).
Game_BoOster wrote:Your Name: [Lsrcr]BoosterI'd like to suggest you to play a bit as Criminal then create such type of suggestions.
Your suggestion: Some improvements regarding the new bomb
Reason: So, let me explain in brief, the new bomb needs some improvements
First of all,I suggest increasing the radius a little bit more to be more effectiveSpoiler: show
? ?? ? ???? ? - Range is still over-powered. Play a bit as a Criminal and you'll know.here i suggest,increasing the time from 0.75 to 1.5seconds because the animation of placing bomb takes more than 0.75 seconds,so the criminals can kill swats easily especially when you're playing alone ( Solo)Spoiler: show
Just reduce the bomb planting animation. (I think it's currently between 4 and 3 seconds, just reduce it to two or two and half seconds)
Third thing, Criminals' shocks damages our hp, so i think that swat bomb should damage the criminals a little bit
This clearly shows that you never played as Criminal after this SWAT update. Criminals are not able to shock SWAT when SWAT has used SWAT Shock bomb within the radius of the other criminals
Thank you for taking time to read my suggestion[/b]
