Hello, Carolj - Thank you for submitting an application to Terrorists
Before we can Accept/Deny you, you'll be tested in some parts in-game. The test will contain your knowledge about Group Rules/ Driving/ Shooting and Task assessment. If you score less than 4/5 in the rules part, your application will be automatically denied. You must also score more than 3 overall, in order to continue with your application. Once you've applied, you can PM a member of the recruitment team if he can take a test but spamming and annoying will lead to the denial of the application.
You can be tested by any of the following Recruiters.
- [Lsrcr]Cena
- [Lsrcr]Marko
- Mr.Killer008
You can also get tested by the head tester:
- MZA1D.
Note: If you failed to explain the code words properly then, your test won't be proceeded and you will be denied.
