I need help! [Reward included]
18 posts Page 2 of 2
Crossbones
Bonez
Post by Crossbones » September 22, 2020, 2:28 pm
This is not normal at all: Image
Fady
Fady
Post by Fady » September 22, 2020, 4:57 pm
Check if your sister's phone has auto-sync turned on, whether it be the normal phone sync or gmail sync. Either of these could be causing your lag. Also, maybe she has applications working in the background, and that can also be the cause so check that out
Faraon78910
Post by Faraon78910 » September 23, 2020, 5:11 pm
what's your net speed? do this and send https://www.speedtest.net
RockingJohnson
RockingJohnson
Post by RockingJohnson » September 23, 2020, 5:21 pm
Toast wrote:
I was facing this issue and it was because of a weak wifi adapter. I switched to LAN cable and that pretty much fixed everything for me.
This works perfectly ^
Regular Player | Need any help? Don't hesitate to contact me via Forums or Discord [Egxie#7546].
Karu_Tepes
[Lsrcr]Lost_Soul
Pagati Don
Event Host Blackmarket VIP
Post by Karu_Tepes » September 23, 2020, 10:04 pm
I asked around... found the solution.
5 dollar ethernet cord!
Plug it into router, plug it into your computer, no issue. Uses a different and more direct port. Even if the wifi drops, you're wired in direct and solid. Requires a total internet outage to fail. Problem fixed.
Crossbones
Bonez
Post by Crossbones » September 24, 2020, 1:58 am
I already have LAN cable as I stated it is main PC not Laptop connected to WiFi...
Crossbones
Bonez
Post by Crossbones » September 24, 2020, 2:01 am
I don’t think this problem is that serious so I buy something like that, with other words, what causes my high ping as I stated above is my sister’s Samsung Galaxy S9. For some unknown reasons, it interferes with my net speed, not just in PC but in overall... the internet WiFi becomes slower too. I need to find a way to stop it from interfering with my net speed, for instance stop data sync media or whatever it is called from the cellphone, for ex.
Karu_Tepes
[Lsrcr]Lost_Soul
Pagati Don
Post by Karu_Tepes » September 24, 2020, 2:26 am
You're not going to be able to. At least not without convincing your sister to let you mess with her phone and I don't think anyone could do that.
Return to “Tech Talk”
