Mechanic Class - Improvement
If you have a suggestion related to our server & gamemode, you can share it here.
9 posts Page 1 of 1
Twitter_2006
Twitter
Post by Twitter_2006 » April 17, 2020, 4:29 pm
Your name:[Lsrcr]Twitter
Suggestion headline: Add/remove this or that:Improvement in /break and /fix commands
Picture: Keep the picture in this:N/A
Importance of suggestion: 1/10 (Shows how much it would mean to server/players):6/10
Why should it be accepted: Type how much you want here to explain your thought: I think we can add a fun improvement to /break and /fix commands. Make them more realistic. I mean the /fix command should have some percentage chance of failing. I mean /fix should fail to work sometimes.Its like how sometimes robbing stores have failed attempts.We should have failed attempts for /fix too which would make cop hunts difficult but realistic. It should be like: ATTEMPT FAILED: You have failed to fix the vehicle. Try again later.
/break can be used in this way but here a failing attempt increases wanted level. (maybe this can be done for /fix as well in cop hunts and cop chases) but anyway.
Thanks!
Karu_Tepes
[Lsrcr]Lost_Soul
Pagati Don
Event Host Blackmarket VIP
Post by Karu_Tepes » April 17, 2020, 9:55 pm
For once, we agree on something. Mechanic class is rather... uneventful, and it has little use. Maybe it should get it's own missions? I think also we could give it the Mechanic Female skin (mecgrl3)
AK33L
[Lsrcr]Ak331
Post by AK33L » April 18, 2020, 6:38 am
Criminal rate is already dropping along with the player base you wanna see tablist always blue? -1 its best as it is
Milyn
Milyn
Blackmarket VIP
Post by Milyn » April 18, 2020, 6:50 am
Please stop
Mechanic class is good the way it is please do not ruin it
AK33L
[Lsrcr]Ak331
Post by AK33L » April 18, 2020, 7:16 am
Milyn wrote:
Please stop
Agreed
Faraon78910
Post by Faraon78910 » April 18, 2020, 4:13 pm
Mechanic class is weak unless there are more mechanic's teaming and this would make it even weaker, -1
RockingJohnson
RockingJohnson
Post by RockingJohnson » April 18, 2020, 6:47 pm
-1 the mechanic skill is dead almost in the server. Secondly there is no particular mean of this suggestion.
Nothing personal :D
Regular Player | Need any help? Don't hesitate to contact me via Forums or Discord [Egxie#7546].
Post by Grand » June 20, 2020, 8:58 am
This is the only last thing that helps criminals cophunt in the server, implementing these things, will both increase the cops rate, and decrease the criminals one.
Balsa
[Lsrcr]Balsa
Post by Balsa » June 30, 2020, 11:35 am
Criminal rate is already dropping so there is no point of adding a command such as this one. As RockingJohnson said mechanic skill is almost dead in server.
-1
9 posts Page 1 of 1
Return to “Server Suggestions”
