Blackouts Application: gameover450 [DENIED]
Gameover50
gameover450
Post by Gameover50 » November 17, 2023, 12:25 pm
Country & GMT: Philippines GMT+8
Playtime: 860h 36min
Rob score: 3 962
Reason: Hi Im gameover450, I'm here to apply in this group and hoping to be a part of it again.
The reason i decided to this group because i believe that my skills are fit to be a part of this group,Secondly i am a friendly person and last but not the least is that the location of the base is perfect for starting a cophunt since it is located in LSA..
Hope you would consider my application and i am Hoping to be one of this group in this coming days..
Best Regards gameover450,
"Black Tigers"
MrMahmoud
Mahmoud
Post by MrMahmoud » November 19, 2023, 11:32 am
Thank you for applying to Blackouts. Your application has deemed correct, but before the Staff team decides either they accept or deny you, You need to pass the in-game test. It contains an interview to get to know you better and see if your english is understandable, and a set of questions about the Blackouts rules and server rules, If you score less than 4/5 in rules part you application will be automatically denied. The rules part consists out a total of 10 questions you may only have two questions incorrect in order to pass.
You must get tested within 7 days, If you are facing any problems within the 7 days feel free to ask any staff member to put your application On-hold if needed.
You can request any of the following Testers to take your in-game test. Keep in mind, Spamming their PM(s) will lead to an Auto-denial to your application.
[b]Bear[/b][b]Exp3rimenTaL[/b]
Mahmoud
Good luck with your test!
Accursed
[Lsrcr]Accursed
Post by Accursed » November 28, 2023, 8:07 am
Unfortunately, Your application has been denied.
Failed to get tested
Feel free to Re-apply after 14 days.
Good luck with your next application!
Blackouts Staff Team
