In life, it's not the most genetic person who wins or the guy who has the most potential to win. It's the person with perseverance who wins. Always wants to get up and go at it again. That's the guy you need to be! - Greg Plitt
RiseOfTheDark wrote:cyclon its not about robbing the bank, i also had this bug.Ohh, you mean that the interior and objects don't load fast enough, you can't spawn properly so you fall. I've never had the bug but it's most likely because of lag or a slow internet connection. To fix it, as you said Rise - close applications that use the internet as it will make sure your SAMP connection is better. You can also try using /reconnect if you get the bug, could fix your desync.
when you are lagged more than 150-200 50% of the times you enter to the bank you start falling.
walmr2nd i suggest you to try to lag less (close programs that require internet before playing, like utorrent, steam, origin etc.)
and take a paracute before you enter the bank, in case you'll fall maybe a nice admin will help you get out of there
