Stormocide wrote:@SkillzI will reply tomorrow, I'm off to bed
Check your PMs
BoSS wrote:Use the stock router you get from ISP. It will be easy for you to set up.Depends who he's going with I'd have to disagree, some of the stock routers they give you are pretty shitty for WiFi depending on your walls in your house, cables that you've got running through them etc.
Skillzz wrote:Can you please check my PM heheBoSS wrote:Use the stock router you get from ISP. It will be easy for you to set up.Depends who he's going with I'd have to disagree, some of the stock routers they give you are pretty shitty for WiFi depending on your walls in your house, cables that you've got running through them etc.
Skillzz wrote:Also yeh Skillzz knows what Im on about xD, I also have a Wifi Extender plugged in right next to my PS4 and PC but PS4 is Using Ethernet as I host Lobbies on that shit. I just need a router that will give me Full service towards my Plan. E.G: If I go 38MBPS i Need atleast 32... Also how tf to people in UK get like 500MBPS Up and Down speed....BoSS wrote:Use the stock router you get from ISP. It will be easy for you to set up.Depends who he's going with I'd have to disagree, some of the stock routers they give you are pretty shitty for WiFi depending on your walls in your house, cables that you've got running through them etc.
Stormocide wrote:Also yeh Skillzz knows what Im on about xD, I also have a Wifi Extender plugged in right next to my PS4 and PC but PS4 is Using Ethernet as I host Lobbies on that shit. I just need a router that will give me Full service towards my Plan. E.G: If I go 38MBPS i Need atleast 32... Also how tf to people in UK get like 500MBPS Up and Down speed....By WiFi extender, do you mean powerline or something that just re-creates the wifi signal?
Skillzz wrote:How much you paying for that a Month? xDStormocide wrote:Also yeh Skillzz knows what Im on about xD, I also have a Wifi Extender plugged in right next to my PS4 and PC but PS4 is Using Ethernet as I host Lobbies on that shit. I just need a router that will give me Full service towards my Plan. E.G: If I go 38MBPS i Need atleast 32... Also how tf to people in UK get like 500MBPS Up and Down speed....By WiFi extender, do you mean powerline or something that just re-creates the wifi signal?
Powerline I'd suggest hard-wiring the devices into, as the wifi on them can be shockingly bad sometimes..
Also, most companies that "promise" speeds can sometimes get away with it if they get you that at off-peak times (around 1-4 in the morning...) it's annoying but sadly the truth haha
Will check forum PMs once I'm home as well.
Also:
