/blowgate by civilians
Bug reports that are very old and may or may not still be valid with the current state of the server.
jilla123
Jilla
Post by jilla123 » November 8, 2018, 4:24 pm
Where does the bug appear: Server
When did the bug appear: Today( As I logged in today and figured it out.
Describe the bug: Civilians are able to use /blowgate without even buying a c4. I conformed it with Hashish whether a civilian can use /blowgate without purchasing a c4 or not.
Currently, LEOs are only able to do that. However, the possibility of destroying the gate is quite less by civilians as i failed all the three times.
Tested it thrice and here are those screenshots :
Mastro
[Lsrcr]Mastro
Post by Mastro » November 8, 2018, 5:58 pm
Devs will be informed, thanks for reporting.
Wajeeh
WajeehiZONFIR333==]
Post by Wajeeh » December 15, 2018, 3:20 pm
Civilians will only be able to blow the gate if they have a C4 from now on. LEO's will be able to use /blowgate even if they don't have a C4 (but with a probability of failure). SWAT members who are carrying a SWAT bomb will be able to blow gate with 100% success (there bomb will be removed after they use the command). SWAT members who aren't carrying a SWAT bomb will have chances of success at /blowgate just like normal LEO's.
Changes to be reflected after the server is updated. Thanks for reporting the bug!
Weeb|Admin|Developer
Return to “Stale Reports”
